ETO ETO Exam papers 📅 Apr 2025
(a) What is back emf? Derive the relation for the back emf and the supplied voltage in terms of armature resistance. (6)
(b) A three-phase induction motor is wound for four poles and is supplied from a 50 Hz system. Calculate: (10)
(i) The synchronous speed
(ii) The speed of the rotor when the slip is 4 per cent
(iii) The rotor frequency when the speed of the rotor is 600 r/min.
(a) Back electromotive force (back EMF, Eb​) is the voltage generated in the armature of a DC motor when it rotates and cuts the magnetic flux. By Fleming's Right-Hand Rule , this induced emf opposes the applied voltage V, as per Lenz's law. Back EMF acts as a self-regulating mechanism that limits the armature current when the motor is running.
Consider a shunt motor:
$$V\:=\:Applied\:voltage$$
$$I\:=\:Current\:flowing\:through\:the\:circuit$$
