(a) What is leakage flux as it applies to the iron-core transformer? How is it considered in the analysis of the transformer? (6)
(b) Three conductors fitted side by side in the stator of a salient-pole alternator. Each generates a maximum voltage of 200V (sinusoidal). The angle subtended at the centre of the stator between adjacent conductors is 20 electrical degrees. If the three conductors are connected in series, find: (10)
(i) the r.m.s. value of the resultant voltage and
(ii) the 'breadth factor'. Using the basis of this problem, give
(iii) reason why are the factors which determine the synchronous speed of a motor?
