(a) What is the operational impedance of an R.C. Circuit? Describe its usefulness. (6)
(b) A ring-main, 900m long is supplied at a point A at a p.d. of 220V. At a point B, 240m from A, a load of 45A is drawn from the main, and at a point C, 580m from A, measured in the some direction, a load of 78A is taken from the main, if the resistance of the main (lead and return) is 0.25 ohm per kilometre, calculate the current which will flow in each direction round the main from the supply point A and the potential difference across the main, at the load where it is lowest?
