(a) Which of the following three motors has the poorest speed regulation:
(i) Shunt motor
(ii) Series motor
(iii) Cumulative compound motor
Explain (6)
(b) A 440V shunt motor takes a armature current of 30A at 700 rev/min. The armature resistance is 0.7 ohm. If the flux is suddenly reduced by 20 percent, to what value will the armature current rise momentarily? Assuming unchanged resisting torque to motion, what will be the new steady values of speed and armature current? Sketch graphs showing armature current and speed as functions of time during the transition from initial to final steady-state conditons (10)
