(a) Why is it important to maintain high efficiency of operation and low values of voltage regulation for power transformers? (6)
(b) A 100 kVA transformer has 400 turns on the primary and 80 turns on the secondary. The primary and secondary resistances are 0.3 Ω and 0.01 Ω respectively, and the corresponding leakage reactances are 1.1 Ω and 0.035 Ω respectively. The supply voltage is 2200 V.
Calculate:
(i) The equivalent impedence referred to the primary circuit;
(ii) The voltage regulation and secondary terminal voltage for full load having a power factor of (i) 0.8 lagging and (ii) 0.8 leading.
