1. With reference to a three-phase shipboard electrical distribution system:
(16)
a) Enumerate the advantages of an insulated neutral system.
b) Enumerate the disadvantages of an insulated neutral system.
c)Describe how the Earthed neutral system is Earthed.
d)Compare the use of an insulated neutral system as opposed to the use of an Earthed neutral system with regard to the risk of electric shock from either system.
### a) Advantages of an Insulated Neutral System (Ungrounded System) An insulated neutral system, where the generator or transformer neutral point is not intentionally connected to the ship's hull (earth), offers several key advantages, primarily centered around operational continuity for critical systems. * **Continuity of Supply:** This is the most significant advantage. A single phase-to-earth fault does not draw a large fault current. The current is limited to the system's natural capacitive charging current, which is typically very small. Consequently, the protective devices (circuit breakers) do not trip, allowing essential machinery such as steering gear, main engine lubrication oil pumps, and navigation equipment to continue operating without interruption while the fault is being located and rectified. * **Reduced Fire Hazard:** The earth fault current is minimal (typically a few amperes). This low current significantly reduces the energy released at the fault location, minimizing the risk of arcing, sparking, and subsequent ignition of flammable materials or vapours.
