Class 2 (2nd Engineer) MET 📅 Feb 2024
With reference to a three-phase shipboard electrical distribution system:
(a) Enumerate the advantages of an insulated neutral system. (4)
(b) Enumerate the disadvantages of an insulated neutral system. (4)
(c) Describe how the Earthed neutral system is Earthed. (4)
(d) Compare the use of an insulated neutral system as opposed to the use of an earthed neutral system with regards to the risk of electric shock from either system (4)
(a) Advantages of an insulated neutral system:
In the event of a single earth fault, no earth fault current flows through the ship's hull due to the insulated neutral, minimizing fire hazards.
The hull does not carry current, ensuring safety from electrical currents passing through the structure.
A single earth fault does not cause generator breaker tripping, avoiding sudden blackouts or operational disruptions.
