Class 2 (2nd Engineer) MEP 📅 Sep 2022
(a) With reference to a vapour compression refrigeration plant, explain why each of the following conditions are desirable:
(i) Superheating at the compressor suction
(ii) Undercooling at the condenser outlet.
(b) Describe, with the ald of a Pressure-Enthalpy diapram, how the evaporator cooling load is affected by the conditions stated in (a)
