Class 2 (2nd Engineer) MEKG 📅 Dec 2019
With reference to Boiler water Tests carried out onboard:
(a) Discuss the possible reasons for the following changes in boiler water test results, and state what actions should be taken in each case:
(i) Reduction in total dissolved solids and chemical reserves.
(ii) Reduction in phosphate reserve, with increase in chlorides and total dissolved solids.
(iii) Reduction in alkalinity reserve only.
(iv) Increase in oxygen levels only
(b) State why the complete results of boiler water tests are logged entered into a data retrieval system rather than a note being made of any particular result which may be outside set limits.
(a) (i) Reduction in total dissolved solids and chemical reserves:
Leakage of treated boiler water (through a leaking blowdown pipe, valve, water tube, or circulating pump) and excessive blowdown both lead to a loss of treated water. Replacing this lost water with untreated makeup water dilutes the TDS and chemical reserves.
Action:
Inspect all boiler blowdown pipes and valves for leaks and repair as necessary.
