Class 2 (2nd Engineer) MEKG 📅 Mar 2024
With reference to centrifugal pumps and pumping systems.
(a) Under what conditions a centrifugal pump require a priming device for pump to operate normally? (6)
(b) Draw a neat graph and explain the performance curves of a centrifugal pump. (10)
### (a) Conditions Requiring a Priming Device for a Centrifugal Pump
A centrifugal pump, by its design principle, is not self-priming. It operates by imparting kinetic energy to a liquid via a rotating impeller. This energy is then converted into pressure energy in the volute casing. This process is efficient for liquids, which are largely incompressible, but highly inefficient for gases like air, which are compressible and have a very low density. A priming device is therefore required to ensure the pump casing and suction line are completely filled with liquid before the pump is started.
The primary conditions under which a centrifugal pump requires priming are:
1. **Negative Suction Head (Suction Lift):**
