Class 2 (2nd Engineer) MEKM 📅 Jan 2024
With reference to crankshafts, explain EACH of the following.
(a) The cause and effects of torsional vibration (4)
(b) The term critical speed indicating why it can be a problem (4)
(c) The term fatigue cracking and state, with reasons, TWO factors of crankshaft operation which have greatest influence on the likelihood of fatigue cracking (4)
(d) How a torsional vibration damper can reduce the effects of torsional vibration (4)
(a) Cause and Effect of Torsional Vibration
Causes of Torsional Vibration
Torsional vibration in a multicylinder engine arises from the dynamic behaviour of the elastic shaft system when acted upon by periodic varying torque. This vibratory motion is caused by the following:
The fluctuating torque imposed by the gas pressure in the cylinders and the inertia forces of reciprocating masses contributes significantly to torsional vibration.
