With reference to feed regulation:
(a) Describe, with the aid of sketches, the operation of a boiler feed water regulator controlled by at least two other parameters besides water level in the drum
(b) Give reasons for the inclusion of the other elements besides water level in controlling feed flow
(c) Deduce the possible effects on the system when the drain valve in the constant leg in the level transmitter starts to leak
