Class 2 (2nd Engineer) MEP 📅 Nov 2023
With reference to fire pumps.
(a) Explain how and when fire pumps should be tested, what are the requirements as per SOLAS74, as amended. (6)
(b) Describe the routine maintenance to be carried out on the various fittings on a fire line, giving testing pressure where appropriate. (4)
(c) Describe briefly how will you dismantle a fire pump for survey. Give details of factors which will decide replacing the parts. (6)
