Class 2 (2nd Engineer) SC&S 📅 Feb 2026
With reference to fixed pitch propellers: (a) Explain Propeller Slip and Propeller Thrust. (6) (b) The shaft power of a ship is 3000 kW, the ship's speed V is 13.2 knot. Propeller RPS is 1.27. propeller pitch is 5.5m and the speed of advance is 11 Knots. Find: (10) (i) Real Slip (ii) Wake fraction (iii) Propeller thrust, when its efficiency, η = 70%
### (a) Explanation of Propeller Slip and Propeller Thrust (6 Marks)
#### Propeller Slip
Propeller Slip is a measure of the efficiency of a propeller's movement through water. It represents the difference between the theoretical distance the propeller should advance in one revolution and the actual distance it advances.
* **Concept**: A propeller operates in a fluid medium (water), not a solid one. If it were screwing into a solid nut, it would advance a distance equal to its pitch (P) for every revolution. However, water is a yielding fluid, so the propeller 'slips' back relative to the water it acts upon. This slip is essential for generating thrust.
