Class 2 (2nd Engineer) MEKG 📅 Aug 2025
With reference to Gear pumps used for lubricating oil transfer:
(a) Sketch and describe a gear type pump indicating the flow of fluid.
(b) State the materials that gear type pump components may be manufactured from.
(c) Specify THREE applications that are suitable for the employment of gear type pumps.
### (a) Sketch and Description of a Gear Type Pump
A gear pump is a rotary positive displacement pump. The most common type used for lubricating oil services onboard is the external gear pump, which consists of two identical, inter-meshing gears enclosed within a close-fitting casing.
#### Construction
* **Casing:** A robust housing, typically made of cast iron, which contains the pump's internal components. It features precisely machined internal surfaces to ensure minimal clearance with the gear teeth, maximizing efficiency.
