Class 2 (2nd Engineer) MEKG 📅 Oct 2025
With reference to hull cathodic protection systems of the impressed current type:
(a) Sketch and describe such a system (8)
(b) Explain how protection may be ensured for the rudder and propeller (4)
(c) State any precautions that should be taken when this type of system is installed. (4)
### (a) Sketch and Description of an Impressed Current Cathodic Protection (ICCP) System
**Principle of Operation:**
The Impressed Current Cathodic Protection (ICCP) system is an active method used to prevent the electrochemical corrosion of a ship's hull. The principle is to suppress the natural galvanic currents flowing between anodic and cathodic areas on the hull surface. This is achieved by impressing a direct current from an external source onto the hull, forcing the entire submerged hull surface to act as the cathode of an electrochemical cell. Seawater acts as the electrolyte. This effectively stops the hull metal from losing ions to the sea, thus preventing corrosion.
**System Components and Description:**
