Class 2 (2nd Engineer) MEKG 📅 Apr 2025
With reference to keyless propellers explain: (16)
(a) How keys and keyways has been eliminated
(b) How angular slip is avoided
(c) Why mounting upon and removal of a propeller shaft requires a different technique than that employed for propeller with keys.
(d) State with reasons why use of wedges and jacks are not advisable when removing the propeller from its shaft.
### (a) Elimination of Keys and Keyways
The elimination of traditional keys and keyways in propeller mounting is achieved through the principle of a high-integrity interference fit on a tapered shaft, secured using hydraulic methods. This design overcomes the significant stress concentrations and fretting corrosion issues associated with keyways.
**Mechanism:**
1. **Tapered Fit:** The propeller shaft tail end and the propeller boss bore are machined with a precise, shallow taper (e.g., 1:20 or 1:30).
