Class 1 (Chief Engineer) Engineering Management 📅 Mar 2026
Q5 With reference to LNG bunkering procedure on board vessels fuelled with LNG fuel. Please explain the following processes: (16) (a) Gassing-up. (b) Cooling-down. (c) Vapour Management. (d) Emergency release coupling procedure.
### (a) Gassing-up
Gassing-up is the process of replacing the inert atmosphere (typically Nitrogen) or air within the LNG fuel tank with warm natural gas vapor before introducing cryogenic liquid LNG. This is a critical safety step to prepare the tank for receiving fuel.
**Purpose:**
* **Prevent Freezing of Inert Gas:** If Nitrogen is used for inerting, introducing LNG at -162°C would cause the Nitrogen to freeze (freezing point -210°C), potentially blocking lines, valves, and instrumentation.
