Class 2 (2nd Engineer) MEP 📅 Jan 2020
With Reference to Main Engine Fuel Pumps:
(a) Explain how the setting of a variable injection timing fuel pump is checked and adjusted.
(b) State why it may be necessary to adjust the settings of a variable injection timed fuel pump.
### Introduction to Variable Injection Timing (VIT)
Variable Injection Timing (VIT) is a mechanism on large, slow-speed marine diesel engines designed to automatically advance or retard the start of fuel injection relative to the engine's load. The primary objectives are to optimize combustion efficiency, control peak cylinder pressure (Pmax), and minimize Nitrogen Oxide (NOx) emissions across the engine's operating range.
### (a) Checking and Adjusting the Setting of a VIT Fuel Pump
