With reference to main propulsion shaft systems:
(a) Describe a method of hydraulic jacking to check bearing loads. (8)
(b) Sketch the Bearing Load versus Shift Lift Dial Gauge Reading graph obtained by the method described in part (a), annotating the graph and how the characteristic of bearing load is obtained. (8)
