With reference to main propulsion shaft systems: (a) Sketch a method of hydraulic jacking to check bearing loads (8)
(b) Describe the Bearing Load versus shift Dial Gauge Reading graph obtained by the method is described in part (a), annotating the graph and how the characteristic of bearing load is obtained. (8)
