Class 2 (2nd Engineer) SC&S 📅 Oct 2024
With reference to membrane tanks for the carriage of liquefied gas at very low temperatures:
(a) Describe with a sketch one method of building up the insulation. (6)
(b) State which alloy is used for the membrane and the reason. (5)
(c) Explain why a secondary barrier is installed. (5)
(a) Membrane tanks for liquefied gas carriage are built with a double hull throughout the cargo length. The insulation system includes the following:
Primary Barrier: A thin membrane made of INVAR (36% Nickel, 64% Iron) with a thickness of 0.5 to 1.2 mm, forming the primary containment layer for the liquefied gas.
Primary Insulation box: A 200 mm thick layer of granulated Perlite insulation packed in plywood boxes, surrounding the primary barrier. Perlite is siliconised to make it impervious to moisture.
Secondary Barrier: A secondary membrane made of the same INVAR material is installed to prevent cargo leakage in case of primary barrier failure.
