Class 2 (2nd Engineer) SC&S 📅 Feb 2026
With reference to membrane tanks for the carriage of liquefied gas at very low temperatures: (a) Describe with a sketch one method of building up the insulation. (6) (b) State which alloy is used for the membrane and the reason; (5) (c) Explain why a secondary barrier is installed. (5)
### (a) Insulation Build-up for Membrane Tanks (Gaz Transport No. 96 System)
A common and effective method for building up the insulation and containment system for a membrane tank is the Gaz Transport No. 96 (GT96) system. The construction is a layered system built up from the ship's inner hull plating inwards towards the cargo.
**Layer-by-Layer Construction:**
1. **Inner Hull Structure:** This is the double hull of the ship, which provides the primary structural support for the entire containment system.
