Class 2 (2nd Engineer) MEKG 📅 Dec 2024
With reference to oil / water separators:
(a) Describe with the aid of a sketch, the working of such a separator. (6)
(b) Explain the consequence if the interface detector position is incorrect. (5)
(c) Enumerate the various possibilities by which oil / water interface can be moved. (6)
### (a) Working of an Oil/Water Separator
**Principle of Operation:**
The operation of a typical two-stage oily water separator (OWS) is based on two primary physical principles:
1. **Stokes' Law:** The difference in specific gravity between oil and water. Oil, being less dense, will naturally rise and separate from water when the mixture is allowed to stand in a quiescent state.
