Q5
With reference to piston rings:
(16)
(a) State reasons for breakage.
(b) How maintenance and engine operation could minimize breakage?
(c) Explain the possible consequences with respect to performance and safety of operating the engines with broken or severely worn piston rings.
### (a) Reasons for Piston Ring Breakage Piston ring breakage is a critical failure mode that can be attributed to a combination of mechanical, thermal, and operational factors. A comprehensive analysis identifies the following primary causes: 1. **Mechanical Stresses & Wear:** * **Improper Handling and Fitting:** Using incorrect tools (e.g., screwdrivers instead of a proper ring expander) can overstress the ring during installation, creating micro-cracks that lead to fatigue failure. Incorrectly set butt clearance can cause the ring ends to butt together when hot, leading to extreme pressure against the liner and subsequent fracture.
