Class 2 (2nd Engineer) MEKG 📅 Dec 2024
With reference to shaft alignment: (16)
(a) Explain the meaning of fair curve or rational alignment;
(b) Shaft alignment is often verified using hydraulic jacks to obtain a simple graph. Sketch such a graph, indicating the following:
(i) Static load
(ii) Hysteresis
(iii) Influence numbers.
(c) Explain the limitations of checking shaft alignment solely by hydraulic jacking methods.
### (a) Fair Curve or Rational Alignment
**1. Concept:**
Fair curve, or rational, alignment is a modern engineering approach to shafting installation. It intentionally deviates from a traditional straight-line (bore-sight) alignment. In this method, the shaft bearings are deliberately offset vertically from a straight reference line when the vessel is in a static, cold condition (e.g., in dry dock). This creates a pre-calculated, smooth, or 'fair' curve in the shaft line.
**2. Purpose and Rationale:**
