Class 2 (2nd Engineer) MEKG 📅 Jan 2023
With reference to sleeved keyless propeller assemblies:
(a) (i) State, with reasons, the metals used in the manufacture of the sleeve and tail end shaft
(ii) State the type and thickness of material used to bond the sleeve to the propeller boss.
(b) When removing the propeller from the tail end shaft, state why the following procedures are not recommended:
(i) Application of push off force by means of wedges or jacks and draw off force by strong back
(ii) Expansion of propeller boss by concentrated local heating with gas torches.
(c) State the correct procedure for removal of the propeller from the tail end shaft
**Error Generating Answer:** Timeout of 600.0s exceeded, last exception: 503 failed to connect to all addresses; last error: UNAVAILABLE: ipv4:216.239.36.223:443: ConnectEx: Network is unreachable (A socket operation was attempted to an unreachable network.
-- 10051)
