Class 2 (2nd Engineer) MEKG 📅 Mar 2025
With reference to sleeved keyless propellers:
(a) State with reasons why the following practices are not advisable when removing the propeller from its shaft: (8)
(i) Expansion of boss by intense concentrated heating by blow torch
(ii) The use of wedges or jacks.
(b) Describe a system that is used to remove the propeller from its shaft. (8)
### (a) Inadvisable Practices for Propeller Removal
It is imperative that the precision-machined tapered surfaces of the shaft and propeller boss are protected during removal. The entire principle of torque transmission in a keyless propeller relies on the frictional grip generated by a precise interference fit. Any damage to these surfaces compromises the integrity of this fit.
**(i) Expansion of boss by intense concentrated heating by blow torch**
This practice is not advisable and is strictly prohibited by manufacturers for the following reasons:
