Class 1 (Chief Engineer) Engineering Management 📅 Nov 2021
With reference to surveying of large starting air receivers:
(a) Explain where corrosion is likely to occur and state why it occurs in these regions
(b) State how the incidence of corrosion in air receivers might be minimized
(e) If serious corrosion is detected in a starting air receiver and that receiver must be used explain how you, as Chief Engineer, would determine the maximum pressure to which the receiver should be subjected
(d) State the further action a Chief Engineer must take upon discovering such air receiver corrosion
### (a) Corrosion in Starting Air Receivers: Locations and Causes
Corrosion in large starting air receivers predominantly occurs in specific areas due to the accumulation of corrosive agents under high pressure. A thorough internal survey would focus on these regions:
**Common Locations for Corrosion:**
* **Bottom of the Receiver:** This is the most common area. Water and oil vapour from the compressed air condense and, being denser than air, collect at the bottom, creating a corrosive sludge.
