ETO ETO Exam papers 📅 Nov 2024
With reference to the 1978 SOLAS protocol which outlines mandatory requirements for steering gear tests and drills:
(a) Describe the test procedure to be carried out within the 12 hours before departure on a sea voyage. (6)
(b) Describe the emergency steering drills that must take place at least every 3 months. (5)
(c) Describe the emergency steering drills that (a) and the drill in (b) should be carried out for ships with regularly engaged on voyages of short duration. (5)
(a) Test Procedure Within 12 Hours Before Departure
As per SOLAS (IMO) regulations, the Master must ensure that within 12 hours before departure , the steering gear is checked and tested to confirm it is functioning satisfactorily.
The test shall include, where applicable, the operation of:
Main steering gear
