Class 2 (2nd Engineer) MEKG 📅 Jan 2025
With reference to the carriage and pumping of liquefied gas cargo:
(a) Sketch a suitable pumping system labelling the component parts. (6)
(b) State:
(i) Why submerged hydraulically driven pumps are not used. (5)
(ii) State over heating of pump drive shaft bearings is avoided. (5)
(c) State why the risk of fire and explosion in cargo tanks is obviated both in the loaded and discharged condition. (5)
### (a) Pumping System for Liquefied Gas Cargo
A typical pumping system for a liquefied gas carrier is the vertical, multi-stage, deep-well centrifugal pump. One such pump is installed in each cargo tank, typically within a pump sump to maximize cargo out-take.
**Component Parts and Description:**
1. **Electric Motor:** A three-phase, high-voltage, explosion-proof (Ex 'd') or increased safety (Ex 'e') motor is mounted on the main deck, outside the hazardous tank area. This placement allows for safe access and maintenance.
