Class 1 (Chief Engineer) Engineering Management 📅 Mar 2023
With reference to the modern analysis techniques employed for the condition analysis of Lubricating Oil, briefly discuss following
(a) Elemental (Spectrometric) Analysis (4)
(b) Fourier Transform Infrared (FTIR) Spectroscopy (4)
(c) Particle count (4)
(d) Base Number Vs Acid Number. (4)
### (a) Elemental (Spectrometric) Analysis
Elemental analysis, also referred to as Spectrometric Analysis, is a quantitative technique used to determine the concentration of individual metallic elements within a used lubricating oil sample. The results are typically expressed in parts per million (ppm). This analysis provides critical insight into component wear rates, sources of contamination, and the depletion of metallic additives.
**Principle of Operation:**
The analysis is commonly performed using Inductively Coupled Plasma (ICP) or Atomic Absorption Spectroscopy (AAS).
