Class 2 (2nd Engineer) SSEP 📅 Mar 2019
With reference to the pump room of an oil tanker describe the following with particular emphasis on satety aspects:
(a) Ventilation system.
(b) Procedure to be followed for pump room entry
(c) Lighting system
Cargo pump-rooms shall be mechanically ventilated and discharges from the exhaust fans shall be led to a safe place on the open deck.
The ventilation of these rooms shall have sufficient capacity to minimize the possibility of accumulation of flammable vapour.
The number of air changes shall be at least 20 per hour, based upon the gross volume of the space.
