Class 2 (2nd Engineer) SSEP 📅 Mar 2023
With reference to the pumping of cargo tanks of chemical tankers:
(a) Sketch and describe an arrangement used with the cargo pump or independently of the pump, to facilitate tank drainage. (10)
(a) State significant regulation which will assist in reducing pollution of sea by chemical cargoes. (10)
(b) Regulations to Reduce Chemical Pollution
The primary regulations for minimizing pollution from chemical cargoes are outlined in SOLAS Chapter VII, Part-B . These regulations refer to specific codes that govern the construction and equipment of chemical tankers.
IBC Code : For tankers built on or after July 1, 1986, they must comply with the International Code for the Construction and Equipment of Ships Carrying Dangerous Chemicals in Bulk (IBC Code) .
BCH Code : Tankers built before July 1, 1986, must adhere to the Code for the Construction and Equipment of Ships Carrying Dangerous Chemicals in Bulk (BCH Code) .
