With regard to care of lubricating oils onboard, answer the following
(a) Microbial degradation of lubricating oil and measures to prevent the same
(b) Methods of ensuring correct sampling is done for the purpose of shore based testing
(c) If the shore based testing results show an abnormal values of water content and TBN for the crank case lub oil of a slow speed main engine, what will be the interpretation and subsequent action?
