With regard to care of lubricating oils onboard. answer the following:
(a) What is microbial degradation of lubricating oil and how is it prevented?
(b) What methods are employed to ensure correct sampling for shore-based testing? What action will you take if the testing results show abnormal values of water content and TBN for the crank-case lub oil of a slow speed main engine?
