With regard to the main turbine lubricating oil system:
(a) (i) Describe the effects of tin oxide corrosion. (4)
(ii) Explain the actions to be taken if this occurs in a high pressure turbine thrust-bearing. (4)
(b) Discuss the factors that determine the various filtration sizes. (8)
