Class 2 (2nd Engineer) MEKM 📅 Mar 2021
With regards to connecting rod ovality of four Stroke Diesel Engine. Explain following.
(a) Importance of connecting rod ovality.
(b) Method of measuring the connecting rod ovality.
(c) Discuss the Impact of ovality if it increases beyond the maximum allowable limit.
(d) Method of ascertaining the elongation of connecting rod bolts.
(a) The connecting rod ovality of the bottom end bearing is caused by cyclic loading and the angular motion of the connecting rod. Importance of connecting rod ovality:
Ovality can disrupt the uniform oil film that facilitates hydrodynamic lubrication. A failure in this lubrication can result in direct metal-to-metal contact, overheating, and bearing failure.
Ovality causes an uneven distribution of forces on the bearing, crankpin, and gudgeon pin, leading to localized wear, pitting, and damage.
If the connecting rod’s deformation affects the piston’s motion, it may cause poor sealing of the piston rings, leading to blow-by gases, power loss, and increased emissions.
