Class 2 (2nd Engineer) MEKG 📅 Jun 2023
With regards to main transmission shaft flange coupling arrangements:
(a) Sketch a hollow type coupling bolt and the hydraulic head/nut and loading rod which are used to fit it. (6)
(b) Describe how the bolt is fitted. (5)
(c) State the advantage of the hollow coupling bolt as compared to the traditional type of coupling bolt. (5)
### (a) Sketch of Hollow Coupling Bolt and Hydraulic Fitting Tools
A detailed cross-sectional sketch is required, illustrating the following components clearly labelled:
1. **Hollow Coupling Bolt**: Showing the central bore, the bolt head, the shank (body), and the threaded section.
2. **Flange Couplings**: Two shaft flanges shown mated together, with the reamed bolt hole aligned.
