With regards to main transmission shaft flange coupling arrangements:
(a) Sketch a hollow type coupling bolt and the hydraulic head/nut and loading rod which are used to fit it;
(b) Describe how the bolt is fitted.,
(c) State the advantage of the hollow coupling bolt as compared to the traditional type of coupling bolt.
