With regards to main transmission shaft flange coupling arrangements.
(a) Sketch a hollow type coupling bolt and the hydraulic head/nut and loading rod which are used to fit it
(b) Describe how the bolt is fitted
(c) State the advantage of the hollow coupling bolt as compared to the traditional type of coupling bolt
