Class 2 (2nd Engineer) MEKG 📅 Mar 2020
With regards to main transmission shaft flange coupling arrangements:
(a) Sketch a hollow type coupling bolt and the hydraulic head/nut and loading rod which are used to fit it;
(b) Describe how the bolt is fitted;
(c) State the advantage of the hollow coupling bolt as compared to the traditional type of coupling bolt.
(b) The process of fitting a hollow coupling bolt into the main transmission shaft flange coupling:
A bolt with a diameter slightly larger than the flange coupling bore diameter (D + 0.00025D) is selected.
A push rod (loading rod) is inserted into the hollow coupling bolt, and a hydraulic head is attached.
