Class 2 (2nd Engineer) MEKM 📅 Dec 2025
With respect to a 2-stroke main propulsion diesel engine starting air system,
(a) Explain the starting air overlap?
(b) What is the starting air timing for one cylinder?
(c) What is slow turning arrangement and what is the purpose?
### (a) Starting Air Overlap
Starting air overlap is a critical design feature in the timing of a marine diesel engine's starting air system. It is defined as the period of crank angle during which the starting air valves of two successive cylinders in the firing order are open simultaneously.
**Purpose and Principle:**
1. **Ensuring Continuous Positive Torque:** The primary purpose of overlap is to guarantee a continuous and uninterrupted turning moment on the crankshaft during starting. This prevents the engine from stopping or stalling between the air admission periods of individual cylinders, ensuring a smooth and reliable start from any crank position.
