With respect to Alternators onboard:
(a) Briefly explain True Power, Apparent Power and Power Factor? (8)
(b) An alternator is rated for 750 KVA at 0.85 PF. What is the maximum load (Kilo Watt) that can be put on it? Would you be overloading the alternator if the kilowatt reading were now 620 KW and the power factor 0.80? (8)
