Class 2 (2nd Engineer) MEKM 📅 Feb 2026
Q9 With respect to fuel injection system of diesel engines, (a) What is the purpose of VIT? (6) (b) How is the end of injection controlled in a 2 stroke propulsion engine and 4 stroke medium speed auxiliary engine? (6) (c) Explain the purpose of a draw card. (4)
### (a) Purpose of VIT (Variable Injection Timing)
Variable Injection Timing (VIT) is a system designed to automatically advance or retard the start of fuel injection relative to the piston's position, primarily to optimize engine performance across a wide load range. Its main purpose is to maintain the maximum combustion pressure (Pmax) at its optimal design value, thereby ensuring maximum fuel efficiency (lowest Specific Fuel Oil Consumption - SFOC).
**Mechanism and Principles:**
1. **Operation at Part Load (e.g., below 85% MCR):**
