Class 2 (2nd Engineer) MET 📅 Nov 2023
With respect to the High Voltage power systems installation, explain the different types of circuit breaker that are used, comparing them on merits and de-merits. Describe the theory of arc phenomenon and the mechanism fitted to mitigate the arc. (16)
Types of Circuit Breakers
1. Vacuum Circuit Breaker (VCB):
In VCBs, the fixed and moving contacts, along with the arc shield, are housed in an arc-interrupting chamber with a high vacuum. The vacuum's excellent dielectric strength allows for very short contact separation and rapid recovery of insulation strength after each interruption .
Merits:
