Class 2 (2nd Engineer) MEKM 📅 Jan 2024
With specific reference to any make, sketch and describe the Cylinder Lubricating system used in new generation marine diesel engines. How will you effect the optimum cylinder oil feed with varying sulphur content of fuel oil. (16)
Cylinder Lubricating System in New Generation Marine Diesel Engines (e.g., MAN B&W Alpha Lubricator)
New generation marine diesel engines, particularly two-stroke crosshead engines, utilize sophisticated electronic-controlled cylinder lubricating systems to ensure precise and efficient lubrication. A prime example is the MAN B&W Alpha Lubricator system, which has become a benchmark.
Description of the System:
The Alpha Lubricator system is a demand-controlled, electronically-driven system designed for optimal cylinder liner and piston ring lubrication. Here's a breakdown of its key components and operation:
