Class 2 (2nd Engineer) MEP 📅 Aug 2025
(a) With the aid of a simple sketch, explain the "trouble spots" in a basic air-conditioning unit.
(b) With reference to your sketch, explain the following:-
(i) How the problem of increase in humidity of cooled air is overcome?
(ii) How discomfort caused by the excessive drying effect of heated air is overcome?
