Class 2 (2nd Engineer) MEP 📅 Dec 2019
With the aid of a simple sketch, explain the "trouble spots" in a basic air conditioning unit and with reference to your sketch, explain the following:
(a) How the problem of increase in humidity of cooled air is overcome?
(b) How discomfort caused by the excessive drying effect of heated air is overcome?
