Class 2 (2nd Engineer) MEP 📅 Sep 2018
With the aid of a simple sketch, explain the 'trouble spots' in a basic air conditioning unit and with reference to your sketch, explain the following:
(a) How the problem of increasing humidity of cooled air is overcome?
(b) How discomfort caused by the excessive drying effect of heated air is overcome
